well i got a tach in my car and up - and running my max rpms under wot is 4000 rpms i want it to be about 500 more because im going to reset the cam to o degs insted of 3 deg retarded witch would improve mid-high end can i ajust the shift points???
retarded cam timing shifts the rpm range HIGHER
Most tranny modulators have a screw inside the vacuum connection.....turning it in raises the shift points (to an extent)
If manual shifts still are limited to 4K, you'll likely need a shift kit for the C4...
Depending on cam and application, you might consider advancing cam for auto app...
Post specs on cam and engine and converter...
