·Gentlemen Has ANYONE had a problem with an intermittent anti-backflow valve from the converter side. ATTN. camachinist!! I rebuilt this trans. VERY carefully using Red-Dog plates and J code springs. Everything operates quite well and seems bulletproof. HOWEVER, every once in a while (when the engine is not fired for a week or two) the fluid level will rise in the case and ostensibly leaks out of the junction of the dip stick tube and the case. (this is an original 68 Torino 24 spline C-4 case). The lubricant is quite new and clean.--Type F. Any comments and suggestions are welcome. Best regards John
