After a few weeks on the hospital I'm ready to get back to the Mustang. I've put new seals on parking brake linkage as it comes out of the case and wonder if there is a manual that would show the linkage and where it all goes.Thanks.
Something's not adding up here. The parking brake linkage does not go inside the transmission.
OK, the linkage coming out the drivers side of the case with the 7/8" (?) nut on the shaft inside the case.
Do you need to see a photo of the linkage that connects the shifter to the to the transmission's shift lever? Something like this?
This is how the linkage is set up on my 67
738242
The shifter connects to that rod up on the top going to the right.
I think that should do it, thanks.
