I have a 65 I6 with C4. from standing start, I feel/hear only one shift. The ATC is good (level).. I'm sure I'm in Drive, not 2nd.. I thought the C4 is a 3 spd.. If it is, any suggestions as to why it isn't shifting up to the final drive? Thanks for info and comments.. Martin
is it a green dot tranny? if so then if you have it in drive you are starting in second gear
If it is a 65, it is a green dot. You should be starting out in the "green dot" in the indicator which is the middle drive position. The first drive position is 2nd and 3rd. The middle is the green dot which is 1st 2nd and 3rd. The last position (or the "lowest" it can go) is 1st or L for low.
