How hard is it to convert a C4 to a T-5. Do I need to fab up a new pedal bracket under the dash or will the clutch bolt up. Also, which bellhousing should I use?
If you get the clutch and brake pedals they will go right in to your stock bracket. I went with a latemodel bellhousing and hydraulic setup. There are many options out there for linkages and kits. Just do some shopping around and you will be able to do it pretty cheap. I think my swap from a auto to manual was about 800 bucks.
Can I use the clutch pedal from a late model mustang or does it have to be from a 65/66?
N
It needs to be from a 65-66. You need to decide if you are using a cable clutch or mechanical linkage. I used a late bell and mustang steve cable clutch kit.
