C4 Trans Dipstick advice
574 Views 2 Replies 3 Participants Last post by  GypsyR
Hi guys, never came across this but moved the trans around the drive and fluid came pouring out of the dipstick hole. Hadn’t happened before in transit but just happened then, and it’s pooled right upto the top. Newbie here, am I worrying about something totally unnecessary? Cheers!
766261
See less See more
Is it sitting level? Did you happen to concave your oil pan? I probably wouldn’t worry about it until it’s properly positioned in the vehicle.
Transmissions drain constantly. I've noted this with junkyard ones for example. They'll dump the fluid out of them when they are removed and put them in the warehouse. Six months later if you buy one you'll find almost a quart of fluid in the pan. If the converter wasn't drained then it's about ten times as bad. A C4 like you pictured without the dipstick in will very slowly make one heck of a mess as it drains back internally and overflows on your floor.
Reactions: 1
