1 - 10 of 10 Posts
Found this in my collection of carbs and would like more information about it. It will need rebuilding, but it's in pretty good shape for it's age. What would a fair value be for this?
I sold a similiar carb . Easy $100-125 minimum
Don't forget to check with the T-Bird, Fairlane, Galaxie and big Merc guys...the nice 4100s are getting harder and harder to find. Somebody doing a correct 64 will go two bills easy.
Just guessing because the photos suck for verifying details, but I imagine the only thing real about that carb is the aluminum tag attached to the top plate.
C4OF-AL is a manual choke hipo carb.
Here's a real one.....
Apparently some carburetor bodies already stamped C4OF AL were built into C5OF prefix assemblies by Autolite. (Fall 1964, way into the 1965 model year)
I think they're still manual choke carbs though and they would have the M and BA boosters and the casting difference in the carb body on the choke side.
You'd have to check Mannel's book, but I think that's the story.
793028
Discussion Starter · #7 ·
I've done a bit more research and there's info out there that may or may not make sense. The Ford Carb book that Pony Carbs did years ago has a section on this carb. It seems that it was also used for Failane, Meteor and Comet hi-po engines, with some using a choke. The venturis match the "M" and "BA" so they're correct. I did not remove the jets. Here's some more to see if any of you have a fair market vale for something like this. By interesting coincidence, the one shown on Ebay has the exact same tag and same date codes! Mine also has that unique hump cast near the choke.
So a very pricey carb, but you know that by now.
Reactions: GT289
^ What he said.
The primary booster is worth bank. The secondary booster, nowhere near so much.
As far as the whole unit, the last one of these (in manual choke configuration) I saw was well over $1000.
1.12 HiPo carb for a non Mustang is still a very valuable carb. I'd say $500-600 as a core, $1500+ in rebuilt/replated/restored condition.
Reactions: PonyDoc
1 - 10 of 10 Posts
