I'm putting a c6 out of a 71 Torino GT 351 4v behind a 70 351c 2v. A Fmx was in the car and the flexplate has torque converter holes that are 11 1/4". The C6 has torque converter holes that are 10 1/2. All I have is the Flexplate for the FMX and it is not going to work. I know someone out there has done this before and was wondering what flexplate you used to match it up.
The convertor in your 4V C6 is the "small" CJ convertor. It also has a higher stall speed than you old FMX convertor. You have two choices. Get the flex plate for a 71-73 351C 4V with the smaller bolt pattern , OR a convertor from a later C6 ( 351M/400) that will bolt up to your FMX flex plate and have the same stall as you used to.
Randy
Reactions: Woodchuck
Pioneer part# for the 351CJ flexplate is FRA-220, which replaces D1ZZ-6375-C. Torque converter center to center bolt pattern on this is 9.5", so re-check your measurements.
