1 - 12 of 12 Posts
As the title says, I need an air horn for a C6ZF-B Autolite 4100 carburetor. The same air horn came on different models and I have attached a picture showing what one looks like.
Thanks,
Allen
What part specifically are you looking for? The air horn is part of the carb top plate and includes the choke plate.
Just curious, what is wrong with the one you have. I haven't noticed much difference between any 4100 top plates.
The 1st picture shows the one that came on the carburetor and you can see the hole that is not covered by the cover in the center.
The 2nd picture is another 4100 cover I have but it has the hot idle compensator system which is also incorrect for this carburetor.
Mine is for a 66 "A" code engine w/o thermactor. Also why I would like to see a photo of the one Bob is referring to...
Allen
I notice yours also only has a bowl vent on one side. So many subtle differences. You might have to find a used crappy carb you can get the parts from, or check with a carb rebuilder like Carbontooter.
1 - 12 of 12 Posts
