REMOVED my carb and intake because it had a intake oil leak. 2bbl. my question is this: right under this carb mounted to the intake first is a 1 inch spacer with a round vacuum diaphram thing with a vacuum hose going to carb. can i just remove this and mount the carb direct to the intake manifold. thanks.(and yes i know ,,just put a 4 bbl on it.... ::
What you describe sounds like a later spacer. Earlier ones did not have the vacuum pot.
I may be interested in a trade: What is the venturi size on your carb? I have a 1.14 66 2V and I probably have the correct spacer as well.
