Ok this helps a lot thank you. I assume pictures speak louder than words. The radio itself is stock but I don't know what the PO did with all the wiring. My new radio didn't come with instructions which to me is really dumb. There was a bar attached to that nut/bolt on the back... I assume for stabilization? I plan to only seek professional help with my painting... trying to solve the problems by myself as well as VMF. Thank you, get back to me about the pictures please.
Ok that pic tells a lot. The two single wires are your radio light (Blue/red) and your power (Black/red) although it may be tough to see the red stripe.
The two prong connector is for your front Mono Speaker..
The screw post on the back connects to the restraining strap. The other end of the strap screws into the dash at the speaker opening. This supports the radio and provides the ground.
The wiring connector with 4 spade connectors is for your emergency flasher switch. It mounts in the glove box.
The other connector you show at the glove box appears to be the front mono speaker wiring.
You said you connected the front speakers but couldn’t find wiring for the back speakers. I suspect you have it backwards. The PO installed rear speakers and you connected to them. You only have a front mono speaker not suitable for an aftermarket radio.. You can replace it with a dual coil speaker or use kick panel speakers.
The switched power wire comes from the accessory feed off the fuze box. You will need to find it. There are a couple sources for battery power under the dash or you can run a wire straight to the battery, the cigarette lighter is a good source since you only need a very small amount of power. You will have to run your own ground wire. Simply run it to a screw that screws into the dash metal.
