Redoing my original 289. I'm .040 over with flat top pistons. I had the heads shaved to 50 cc. What am I looking at for compression ratio? How do you figure out my comp ratio. I'm thinking 10.1. Am I close?
Thanks, yarb
68 Mustang Coupe
1967 Mustang Convertible
As pointed out you still need to know piston cc, deck clearance (how far is the piston in the hole) and which head gasket you are using to know compressed gasket thickness. Then you can use the calculator above to determine Compression.
Using the somewhat standard rules of thumb for some of the numbers in case your engine is already put together and you didn't measure some things, I get 9.92:1. It could be a bit more if you have no eyebrow flat tops or less if you have 4 eyebrow flat tops.
The small head chamber makes it very easy to get 9.5-10+ using my list of some basic generic numbers. Plenty of options to go either way from there.
So whats the rule on head shaving until the intake needs cut as well?
10 to 10.4 depending on how close the piston is to the "deck" of the block. Flush is 10.4 and .010 below is 10.1 to one
