Back in 2010 I was rebuilding my engine, I asks for advice on a choice of cams to go with what I wanted.
I told the tech that I had a C4OE five bolt 289 block bored .040 over, stock crank and rods, Speed Pro flattop hyperthereticut pistons.C4OE heads that were milled and port matched new valves 1.94" intake, 1.6" exhaust, treaded rocker studs, the carb I'm using is the original Autolite 4100 1.08. and a Edlebrock 289 performer intake with a 1" thermal spacer between the intake and carb, I believe I'm running a 3:1 rear behind a T5 trans out of a 94 V6 Mustang. I told the tech that I didn't want my car to be heavily loping when stopped in traffic, but quick off the line with excellent throttle response and decent gas mileage without putting my foot into it, . He threw several cam ideas at me, I chose the Crane Energizer 130032 kit. It's specs are:
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,200-4,200
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 204
Duration at 050 inch Lift: 204 int./204 exh.
Advertised Intake Duration: 260
Advertised Exhaust Duration: 260
Advertised Duration: 260 int./260 exh.
Intake Vave Lift with Factory Rocker Arm Ratio: 0.456 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.456 in.
Valve Lift with Factory Rocker Arm Ratio: 0.456 int./0.456 exh.
Lobe Separation (degrees): 110
After assembly and getting the engine dialed in the car is very responsive, doesn't stumble when going WOT from a stand still. I chose the Crane mainly because they have been making cams forever and the brand was extremely popular back in the day.
I'm considering going with a Holley Sniper or FiTech EFI setup down the road. will EFI change my cam requirements? As an after thought with my setup are there cams that would be better suited, giving me excellent throttle response and maybe even more power or should I be happy with my setup. I know I could go with a higher lift but was afraid I'd get the lope I wanted to avoid, or is the lope caused by separation or duration or something else?
