1 - 2 of 2 Posts
Trying to find a cam to bleed off a litte compression on my Cleveland. Here is the Combo, 351, .030,flat tops, 2V Aussie heads, Edelbrock 2v intake, Holley 715 vac sec, c-6, 3:50 gears. All in a 73 Convertible. Suggestions???
Here is what Comp Cams suggest.... Part Number 32-309-4
Engine 1970-present Ford
351ci-400ci
351C, 351M-400M,
8cyl.
Grind Number FC 268AH-8
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.531 0.531
Duration At 0.006 Tappet Lift 268 276
Valve Timing At 0.006
Open Close
Intake 26 62
Exhaust 66 30
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 222 226
Lobe Lift 0.306 0.306
Lobe Separation 108
I went with a Comp Cams 282s Magnum - my build is almost exactly like yours; .030 over with TRW flat-tops, Aussie heads, Speed Demon 750vs carb. Duration is 282/282, 236/236 @ .050", .570/.570 lift, lobe sep 110. Advertised as 2000 - 6000 rpm range. Might look at 270 Magnum, Lunati Bracket Master 2, or similar if you don't want to mess with a stall converter.
Doug
1 - 2 of 2 Posts
