Hi,
I am going to swap the cam in my 71 Mach 1 with a 460. I just wanted to know what kind of idle characteristics and overall performance I can expect from the cam I am considering. The specs for a cam that I already have and may install:
288/298 @ full
228/238 @ 50
544/544 lift intake/exhaust
114 deg lobe seperation
Powerband 2500-5500
Engine specs are:
Pocket ported heads
9:1 compression
Holley 750cfm mech sec
Performer Intake
Hooker Headers w/3" dual pipes and Flowmasters
2200 stall
3.25 rear end
The wide lobe seperation and short .050 duration will make that a great street cam. Personally, I'd call that the smallest performance cam for a motor that size, but it will certainly run nice. I run an almost identical cam in my 390 in a 4x4 truck, and it has great vacuum, good idle, but you can tell there is a cam in it from the exhaust sound at idle. You should have no negative effects what so ever with driveability, its a very good match for your setup
