i want to know if you can run a car deck CD player off an outlet in the wall. I of course would have a professional do the wiring. I have an old gas pump and i am restoring it. It is cooler in my opinion to have a gas pump that does something other than sit there so i am going to make a stereo out of it. maybe!!! thanks
jake
Yes you can do it. You need to go to Radio shack and get a step down transformer. Or a 12V power supply. It plugs into the wall and on the otherside is a lighter plug usually, you can cut the plug off and get 12V. The key is to step the 117V house AC voltage down to 12-13V DC.
Kory
Mustang Parts makes a great addiction.
I just tested my '67's radio with a $10 cheapie power adapter from Best Buy. Plug it in, select the voltage, hook up the wires, and you got tunes man.
http://my67heven.tripod.com/emsm.gifI was looking for a restoration of fantasy. I do not want my car to be as it was in 1967. I want it to be as I imagined it in 1967. -John Baird
Got Rust? 1967 A-Code Coupe
You will need a 120VAC to 12VDC converter. Then hook the CD to that. Bear in mind that some of these converters will make a "hum" and the sound quality will suck. Why not find one of those "headboard stereo's" and install that?
Hal
Never drive faster then your guardian angel can fly.
**Wear your seat belt**
PS, that's my 'bird...... My Mustang is too ugly to take pictures of yet........*G*.
http://www.teleport.com/~cosa/bird2.jpg
Moderatly Old Fart
We used to use a special power supply for CB radios. (remember those?) It eliminated the 60hz hum. 120VAC to 12VDC Plus it could put out a few watts where the little traansformers you plug in the wall might not.
Gene J
http://albums.photopoint.com/j/View?u=1584519&a=12110688&p=43875040&Sequence=1&res=high.jpg
66 Coupe/66 Convert/84 GT Turbo/96 coupe
Gene's cars
If you can find an old computer (like a 286 or 386) with a 200 watt or better power supply, grab the power supply and throw the rest out. Just have your installer find the 12v lead.
Those older supplies are isolated and regulated (= sweet).
NJDave
