1 - 10 of 10 Posts
I think mine is bad, wipers won't go to park, they just stop whenever I put the switch to off. I tested the motor (found a process on-line) and it checks good, will go to park when tested. Would like to find a guide to checking continuity in low, high, and off (park). Any help would be appreciated, thank you!
Check the ground at the motor. Also, I believe these motors have a park switch built in that could be bad.
I just checked my manual and there is a park switch in the motor and it is adjustable. Your switch has nothing to do with the park function.
Ford factory service manual. Mine is in PDF and I cant copy the directions for you for some reason. I got the whole manual for around $16.00 online. Its been a lifesaver.
Agree with the motor being the issue. I've never had a bad wiper switch, but have had to clean plenty of the motors to get them to park correctly.
This is the manual you want.
https://www.npdlink.com/product/sho...=manual&top_parent=200001&year=1970&year=1970
FYI -the PDF versions are nice if that's how you roll. From what I've heard, some versions are locked so you can't even print off the pages you need. Buyer beware.
Since the motor runs, that is not the problem. There are two park switches- one in the dash switch, and one in the motor. One of them may be bad, or the connecting wires may be disconnected. This schematic shows how the system in a 69 works- I assume the 70 is the same or very similar since they are brother cars in most respects:
Discussion Starter · #8 ·
Discussion Starter · #9 ·
Thanks Mach1 Driver!
It does look like there is a contact between Lo and Off in the switch. I suppose it could be dirty but I doubt it. I would focus more on the park switch in the motor.
1 - 10 of 10 Posts
