New territory for me... I have a slow leak; but no time to repair it for a while. It took a good month for the refrigerant to completely drain – and with the cost of 134 so low – I thought if I could recharge the system myself it would last me through August.
What exactly do I need to do? Any special tools or equpment needed?
Thanks for any advice!
Any parts store will sell what you need to recharge your 134a A/C. I would recommend you put in the kind with leak detect then you can find out where it is leaking.
Dan didnt you just have that installed last month? Check the fittings to see if they are tight, its a small job looking for the leaks. And just as easy to fix, Not like a leaking rear main. ::
Oh and what is the status of your fuse blowing-fuse block heating problem? If you posted a follow up I seemed to have missed it. John
