I have the cable clutch from modern driveline for the T5 conversion. I am switching to the tremmec TKO, can I use the same cable clutch set up?
You may need an adapter to mount it to the trans. Check with Bruce. The part listing on the Modern Driveline site lists the same part for the T5, Tremec and T56, so I'd suspect that you will be fine.
Check out my web page and see my cable conversion. The cable only cost $60. If you have a way to machine a couple of plates then it's very simple to make. You can adjust the cable at the clutch fork. The cable is shorter and fits nicely around the headers. You do need to weld two pieces with my set up.
