Maybe your RH wheel camber is close to 0° and your LH wheel has a little camber, in either direction. Meaning your LH contact patch is smaller.
Or your tire wear is not the same RH/LH.
Just replaced RH caliper and brake hose (I assumed that was the issue as that was all that is left)
Guess it depends on if “increase” means increase the front brakes, or not. Might be worth turning the other way a bit. Seems suspicious since the fronts only lock.Could be alignment I suppose, but sure feels like the physical brakes (feels like it gets grippier and grippier/brakes work better the more I use it on the lh side).
HP, no I think it's like a diaphragm regulator where clockwise opens it up. It's definitely not nothing and then too much. It's still very much modulated, just doesn't get as hard/lockup as I would like.
I wonder if just the low vacuum/SLIGHTLY less psi at the RH caliper is causing it? Seems like a stretch but I'm running out of ideas.
Also I would have thought a fully open prop valve would allow the rears to lock on pavement?
I'd give the caliper slides and leaf springs a good hard look... the mounts, too.Seems a little low to me too, but I've never measured any other car!
Bart, rod end adjustable strut rods, tight. Wheel bearings tight, calipers newly removed and reinstalled (when I replaced the RH caliper and did the pads last week. Maybe LCA or sway bar?? But, I scuffed the rotors as well so tomorrow I'll be able to see if everything is wearing properly.
So I went out for a drive and did 3 panic stops (well, I did a lot more, but only photographed 3 of them). So I can lock them up, but they lock later.. And the second time, looks like it did not lock. (I think locking the rears is definitely out of the question though). I mean, maybe the 2nd stop the rh would have locked if i pushed more, but, still something seems fishy to me. Shrug?
You know, a smarter man may have checked the proper operation of that valve when he had a gauge attached to the rear calipers..Might be worth turning the other way a bit.
Lol! We have all been there. And will be there again.You know, a smarter man may have checked the proper operation of that valve when he had a gauge attached to the rear calipers..![]()
I agree with this. I had the same problem with my truck. It turned out that the lining of one of the hoses had a hole in it and fluid pressure to the calipers would be delayed on quick application of the brakes. It would even out after a couple seconds. Skid marks looked the same as yours.swap flexible brake lines side to side and see if it follows the hoses. Heck they're cheap enough to just replace for good measure. I've had one swell pretty noticeably on brake apply and the car would pull to the opposite side on a hard brake apply.
