1 - 15 of 15 Posts
I am looking for an air breather for this carburator.1970 1971 Ford Mustang Maverick carburetor new Carter D2DZ-9510-f. I have a 1966 Mustang 200 I 6 and somewhere down the line someone put a 1970 motor In It. An Autolite 1100 air breather won't fit. The diameter is smaller. Also the choke sticks up to high on the Carter. I discovered all this when I pulled the head to do a valve job.
Not a sure thing, but the autolite 1101 carb had a high choke on it that 1100 air cleaners don't fit either. Maybe an 1101 air cleaner will work for you.
Reactions: bebgas55
Reactions: bebgas55
I ordered this air cleaner. We will see if it works?
looks like my will fit for 65 66 i had a 69 did not fit Sell for $100 + shppiing text me if you want a pic 727 808 9804
It's that big round tin can that sits on top of the carb. LMAO. Sorry, I couldn't keep my fingers from the keyboard after reading your heading. Seriously though, you might find one for the 70 maverick that will fit (or possibly modify a stock L6 to fit).
Where are you located. My 65 had a Carter on it that I've replaced with a proper Autolite 1100. Carb and air cleaner are sitting in my garage taking up space.
Yep, That's the Carter YF-1 Air Cleaner. Ford started using them on the Mustang and the Falcon in 1970...as well as the Maverick..
1 - 15 of 15 Posts
