1965 Mustang coupe 289 C code. Caspian blue w/ white top and interior
289 4v ford intake, 4150 holley that is new.
Went on a test drive the other day and the cam follower(?) on the points snapped of making it so that the points wouldn't open or close. Replaced those on the side of the road and got home just fine. The following day I started the car and it was a little hard to start, but it started. After letting it warm up a bit, I tried to give it the slightest amount of gas and the engine just did not want to increase at all in RPMs. It sounded very weird almost like it was chugging for lack of a better term.
I pulled the plugs and 1/8 were normal and the others were fowled up maybe because of my points issue.
I am really stuck as to what could be causing this since the car runs great if it is just idling there.
Maybe one thing worth mentioning is that a week ago I had a bunch of problems with my sending unit and finally got that all turned around. I checked my fuel filter and it was loaded up with tons of crud red mud and swapped to a new filter.
Maybe there is a blockage and the carb now has some of that junk that was sitting in the filter housing?
