You'll need a toothbrush and Q-Tips™ for removing the last of the wax and polish. Use Westley's Belche-White™ on the tires, inside, outside, and the tread.
+1....If your going to show your undercarriage Wipe with water and micro fiber towels if the u'carriage is somewhat clean. When you get close to any oily areas, I use a greasy rag just for those areas and keep them separate in a big slip-loc bag.Clean, clean, and clean. Clay bar the paint, then polish it. Use Windex in the engine compartment to clean the painted surfaces since it won't damage them. Clean your tires and get the pebbles out of them. Don't put that glossy spray on them, but if you insist on using it, don't get it all over the ground around your tires. Dust your interior, vacuum your carpeting, and set the seatbelts in a nice position so that they are straight and even. Put your front seats in the same position, too.
You can use Q-tips to get into airvents and some places in the engine compartment, too. Use a lanolin hand cleaner to clean wiring and rubber hoses. Put a little in your hands and rub it into the wiring and hoses, then wipe down with a dry shop towel. Get all the bugs out of your radiator.
Good luck!
Wow, Awesome.Cleaning is everything. Maybe 15 years ago, a woman I knew who had a completely original 69 mach1 went to the Nationals. An hour before judging, her mandatory fire extinguisher burst, drenching the interior with foam. The judges waived the owner prep only provision, and a whole team of guys re-detailed her interior. She got her preservation award. She passed on just a few years later. The car is still around, still wearing the original Raven Black paint and black interior.
LOL! I agree completely.All of the above apply. However, the whole process can get a bit out of hand. The best. John--Las Vegas
Well stated. As a Gary, Indiana native, you took the words right 'ouch' my mouth. Best regards. John--Las VegasLOL! I agree completely.
I generally keep my car pretty clean. Every spring I go through a four stage polishing process that is essentially my prep for the entire season.
My prep for a particular show involves driving there!
You could get 1,000 answers with 10,000 different products, and they'd all be fine... Please don't take it the wrong way, but you just need to head over to Walmart, and..OK so I am not getting many replies.... How about this??
What do you use for Tire Dressing?
What do you use to Clean Engine bay?
Cleaning Seats?
Window Cleaner?
Detailing Tools?
Not to steal the post, but somebody want to explain "Clay bar" to me?Clean, clean, and clean. Clay bar the paint, then polish it. Use Windex in the engine compartment to clean the painted surfaces since it won't damage them. Clean your tires and get the pebbles out of them. Don't put that glossy spray on them, but if you insist on using it, don't get it all over the ground around your tires. Dust your interior, vacuum your carpeting, and set the seatbelts in a nice position so that they are straight and even. Put your front seats in the same position, too.
Good luck!
