1 - 11 of 11 Posts
Hi all,
My new '67 GT seems to be idling a but too high...about 1300. I tried to drop it down today and the car started and I pulled out of the garage but whe I went to open the door to get out, the interior lights came on and the car stalled. Same thing happened when I got it back running and put the headlights on. I had to pump the idle back up to keep it running with the lights on.
Alternator? Voltage regulator? Get rid of the ballast resistor?
Any thoughts?
Thanks,
Mike
Cool multiple choice question. /forums/images/icons/cool.gif
A) Alternator
B) Voltage regulator
C) Get rid of the ballast resistor
D) Battery (I added that one)
E) none of the above
I choose D /forums/images/icons/smile.gif
All kidding aside check the battery. fd
I had the charging system checked at Sears last wkend and they said the battery and alt. seemed fine...under a load it was putting out about 13.5V.
Mike
Ignition coil, anyone?
Discussion Starter · #6 ·
The car does have a new Flamethrower coil and Petronix.
Mike
Take me too lunch, I'ff fix it for you. *LOL*
Sounds like something is loose to me. Ignition switch maybe. Is the electronic ingnition hooked up to 12v?
Seriously, bring it by an we'll put it to some volt tests and see what shakes out.
J. Boggs.
Discussion Starter · #9 ·
I think this might be the case...is there a way to determine if I still have the resistor wire in the factory harness by looking at it or doing some testing?
Thanks,
Mike
Turn the key to ON, and measure the voltage from the input side of the coil to ground. You may have to bump the dizzy a bit. If the reading is about 12V, you have no ballast resistor wire. If it is about 6-9V, you do.
Discussion Starter · #11 ·
Hey Midlife,
Thanks for the info. Now I have to get a voltage testor!! When I moved out and south all of "dad's" tools/toys stayed that the house! Will be nice when they move close by in a few wks!
BTW, that pic in your signature is great!!
Mike
1 - 11 of 11 Posts
