My Edelbrock 600 carb has sticking floats , stuck down as it is flooding . Is there anything short of removing the top that can be done.
I screwed up and didn't put any gas treatment in it for the winter ,
I have an Edelbrock 600. It take about 2 minutes (or less) to take the top off. When you do the floats lift out of the bowls with the top. Should be easy to clean from there.
X2 Just be carefull not to damage gasket or buy a new one ahead of time.
Before putting it back together, you might want to check the level of the floats. I believe its supposed to be 7/16. You can use that size drill bit as a gauge.
