I am sure opinions vary, but I am looking to purchase a Carb and intake combo for my 302. I need something that will match my poorly mismatched motor. Cam is 270 duration, 501 lift, and heads are 2.02 intake/Exhuast. As you can imagine, I need to boost bottom end power. I am thinking Edlebrock air gap, and a 600cfm carb from them as well. What do you think? I like speed more than driveability, although it is nice too. Any thoughs on the Baryy Grant Speed Demon? ::
boost bottom end power?
270 degrees NET or GROSS duration?
Im assuming you mean gross.....if so, cams with 270 gross duration shouldnt suffer from poor low end.
I would use a carb around 575-625CFM. Edelbrocks are nice for those who dont want to tune.
Keep in mind the ideal total ignition advance and rate of advance will probably be a little different than stock motors like.
Lost of folks disagree, but I think the demons and avengers are overpriced.
My engine is a similar build. +.040 302, 270 magnum cam, 289 heads w/1.94-1.6 valves, etc. I have a Shelby type dual plane intake and a Holley 600. It made 330 hp without really tuning it. I might go with a Torker 289 or a Victor jr. next.
