1 - 11 of 11 Posts
im looking to buy a Phenolic carb spacer for a edelbrock carb and have a couple questions, is there a big difference between 1/2 inch and 1' as far as insulating , also there are so many brands and styles out there , which one would be a better choice, any info would be a great help
I'm sure there is less heat conductance for obvious reasons and yes, the additional height is a good thing, but, you run the risk of your A/C nut contacting the hood. I'm running a Performer RPM, and when running my Holly with a drop base A/C and a 1/2" separator, I had to use the K&N Extreme cleaner top with the recessed wing nut relief, so as not to contact the hood when closed.
Something to keep in mind.
i also have a Performer RPM but have a shelby fiberglass hood so im hoping the hood gives me enough clearance to run the 1 inch spacer, has anyone used summit racing spacers or should i consider another brand?Summit Racing SUM-G1404 - Summit Racing® Carburetor Spacers - Overview - SummitRacing.com
Hi,
If you have that "scoop" thing going on you'll probably be fine. Any good "phenolic" (non-conductive) spacer is good. Jegs/Summit, who ever is closer, they are all about the same money.
Happy Motoring!
I used a 1/2" phenolic spacer and a drop base air cleaner to use a 2.5"-3" air filter on my high rise weiand. Even the 1/2" spacer made a huge improvement to my carb temps. before spacer the carb was just as hot as the intake ~180*-200*, after spacer install I could lean on the carb, warm but not burning hot. I took temp readings before/after with an IR but forgot to write them down.
I don't think you'll see a difference in perf. from one brand to another, not measureable anyway. I just bought the cheapest phenolic from Summit.
Jon
I have the 1 inch spacer on with an air gap intake. I also have the shelby hood. I am running a narrow oval air cleaner and I had to delete the supplied plastic braket from the air cleaner to solve clearance issues. Even now I am right there... you could not fit a you know what in there now.
On higher compression motors, the 1 inch spacer showed a 10 hp gain to the wheels, not to mention the cooler fuel (as mentioned above). It will be close, but make it fit... it is worth it.
Don't get a cheap generic one. The one I got was warped. I then went with a Moroso and all was well.
Reviving a old thread with questions. Anyone know if a 1 in spacer hurts lowend off idle power more than a .5 inch I would think so. How do the clover style spacers work over open and 4 hole ones. I was thinking it might be a good compromise over open, on a street motor. I think I can get a 1 inch under the hood with my drop base, hitting the playdoe test there in a min. I have a ebrock right now that heat soaks and vapor locks after it sits a couple minutes. I what to replace with a holley later this year but cant afford it right now.Thanks.
Hi,
No doubt you'll get many answers to you question of which works best. Unless you are on a Dyno, swapping manifolds with a known good well tuned carb, it's all going to be a "WAG", as each of our engines are different. Generally speaking, dual planes favor low-end TQ, while single planes favor top-end. Four holes favor low-end, while an open chamber tends to mid and upper ranges. Spacers increase the roof of the intake floor, thereby, allowing a smoother transition of the column of incoming mix which tends to favor higher Rs. Not to mention, they reduce heat to the carb, as we like. Non metallic, low-heat conducting spacers are favored, unless carefully machined in such away was to create a cooing affect in the case of aluminum.
Anyway, I think, I got this right.
However, my question..... Why you blaming the Eddy for heat soaking and vapor lock? It's not the problem. Not running a spacer, is more likely the culprit, unless you have an engine running hotter than normal.
Happy Motoring!
If this is going on your 331 I would stay with a 1" open spacer. you really do need a better carb for your 331. you are leaving some power on the table with the edelbrock. I like the Holley 4150 street HP if you do not need the choke. Great carb for the money.
YEa it my 331. The spacer Im thinking of is the Dart drt-62100002, its a 1 inch phelic. I would link it but dont know how. I m going to the 650 dp late this tear just cant swing it right now.
Your right the 4150 street HP is a nice carb. May be going that route at a later date.
1 - 11 of 11 Posts
