1 - 9 of 14 Posts
· Premium Member
1965 Mustang GT. 11.898 @ 113.646, all motor, three pedals
That 6-32 Allen set screw (just forward of the primary idle speed screw) is a throttle stop. At WOT the linkage arm will bottom out on it, you can raise or lower it to get the butterflies vertical.
75/82 is one helluva lot of jet for 302 cubic inches. What altitude are you at?
· Premium Member
It’s missing the nut that retains the linkage head to the primary shaft.
I also have set my primaries so a small square is visible of the transfer slot, however, the spring that my accelerator pump cam sits in front of prevents my throttle from closing all the way so the amount of transfer slot exposed is more then I would like right now
Are you talking about this?
Wood Auto part Rim Hardwood Flooring
· Premium Member
On setting the secondary throttle plates: 1/8-1/4 turn from being completely shut. Hopefully there will be little-to-no secondary transition slot exposed, which is what you’ll want. But you don’t want the plates bound in the bores either, so you have to open them a little bit.
· Premium Member
ill send a picture when im back at my house
Excellent 👍
I‘ll look up Slayer calibration specs, BRB
edit: is this it?
· Premium Member
On transfer slot exposure: primary side, roughly a ‘square‘ or short/stubby rectangle is ideal. If you have little-to-no exposure on the secondary side, that’s good. Provided that the secondary plates are not shut completely and bound up in the bores.
Your pic with the red circle is how you ‘set’ the secondary side. That’s the screw you’ll want to back out (down) until the secondary plates ~just~ close completely, then give it 1/8-1/4 turn so there is no bind.
· Premium Member
Primary jets 68-70, put a stiff-ish vacuum spring in it, and it’ll run like a scaled dog on a 302 😉
· Premium Member
edited… I don’t need to make this any more complex than it already is 🤪 We’ll cross that bridge if we come to it
· Premium Member
Purple is a good spring tension for that carb/motor combo. I’d run it as-is for a baseline and go from there. But yes, it might want to be slowed down a little but you won’t know until you test. Resist the urge to change too much all at once… don’t ask me how I know 🤪
· Premium Member
Just a comment on YouTube videos: there is some good information out there, but there’s also a lot of crap. You may have to sift through the crap.
I‘d browse a few different channels and compare information… if you get the same or similar info from multiple sources, chances are it’s reasonably solid. But if one guy claims to have solved the mystery of carburetor tuning all by himself, I’d be speculative.
1 - 9 of 14 Posts
