On my 302 with Holley 2-bbl, I was trying to set the timing using the procedure previously described: Attach gauge to a vacuum source and with engine at idle adjust distributor to achieve maximum vacuum (less one inch). When attaching the gauge to the carb-to-distributor port, I got no reading. I noticed also that the choke tube inlet was sucking air, so I plugged that temporarily. Questions are: (1)where do I attach the gauge to get a good reading, (2) what should it be, and (3) why is the choke tube inlet showing a vacuum?
No disprespect, but manifold vacuum is a legitimate way to find optimal timing. Adjust/rotate dizzy until maximum vacuum is found, test for pinging. If pings, then back off slightly, retest.
It is manifold vacuum, not carb ported vacuum that is required for this.
http://clubs.hemmings.com/baymustang/platesmall.jpgLet me check your shorts! My multimeter is just a-waiting! Formerly known as Midlife in the old VMF.
King of the Old Farts *struts*
Find a port directly off the intake manifold. My C-4 has a transmission vacuum line, off a fitting at the rear of the carb, and it works great for that.
http://66cherry.stangnet.com
Member NTMC
http://albums.photopoint.com/j/View?u=1611748&a=12299913&p=45161411&Sequence=0&res=high.jpg[/url]
