I have a 66 mustang with a center console with a 4 speed shifter plate insert on it. When i put in my t-5, will the hole in the floor and hole in the center console line up. I will be using the replacement "look-alike shifter", so will that fit in the console too? Also are the dimensions the same for a t-5 and tremec transmission? I dont want to do any cutting.
I've done the swap with no problems. The only issue and it's a small one is that the console shift plate hole favours one side a little
I used a B&M Ripper Shifter with an original T-5 Shifter lever. It fit fine.
http://www.midnightdsigns.com/james/images/console%20003.jpg
