21 - 29 of 29 Posts
I used the E-brake out of an 86 Mustang GT in my 66. I did add a reinforcement plate underneath the floor with welded captured nuts to bolt everything down. Surrounded in in a DIY console that I tried to make look like a 68 Shelby setup.
1968 Mustang coupe, 331 engine
Im resurrecting this thread because I searched around and this was probably the most relevant one.
I want a tunnel mounted E brake. Personal preference I guess, but I dont want electronic, or foot operated. Im doing a manual conversion and I like having a hand operated brake for hill starts.
I have an 8.8 rear from a 95-2000 explorer with disc brakes. I will have a TKO in there, so I figure while the tunnel is empty and the seats/carpet is out for me to install the trans, the time is right to do the handbrake. I really want to be able to build a custom console around it, arm rest, cup holder or two. Right now I see that the 05-09 mustangs had a handle that is offset to the drivers side out of the way of other things, and has a cable that is housed so you can locate the balance/splitter piece further down the tunnel. I like the look of that, and the handles are fairly cheap - the later Fox body handles are quite pricey now, and I dont like the amount of cutting required for the lokar handle (or the design of it - looks really tight to the floor when its "down").
Im wondering if anyone has seen an 05-09 system adapted to a classic? or if anyone has experience working on such a handle? Those cars had an 8.8 rear end too, so do you know if the parking brake mechanism was similar to the explorer system (mini drum brakes inside the discs)?
Hi, how ya doin
I installed a center mount emergency brake from a 1987 Mustang in my 69 Coupe & used the Lokar emergency brake cables & the Ford Racing front parking brake cable #- M-2810-A to hook the hand brake to the Lokar brake cables. I also made a trans tunnel support piece for where I installed the emergency brake handle.
745827
745828
745829
That's awesome. I think I'm going to go with a newer style handle because I can get a brand new one cheaper and they mount a little off to the side. The downside is I will need to fabricate a special hump on the tunnel. The cable side of it will be fun I'm sure.
65 Fastback 289 4 spd, 65 convertible 5.0L 5 spd. 3.73 8.8
I have an explorer 8.8 and I used 2 right hand cables for explorer, made a mount under plate (convertible) to hold cables. I cut 7 rings off of springs to make it the right length and take strength out to be able to pull the original under dash hand brake. used a generic throttle spring to hold some tension on ft. cable. Its was touchy to adjust.
Just some guy
On mine I took a sharp chisel and a hammer to the junkyard and chopped out the brake and a good part of the sheetmetal around it. Then at home I cut my tunnel and trimmed up the donor section with power tools until they mated to my satisfaction and welded them. No "fabrication" needed.
(These days I have a battery powered sawzall.)
Updating this thread. I have installed a 2010-2014 Mustang parking brake on the tunnel. No cutting or welding of the tunnel needed, just one fairly large hole for the cable, and 3 smaller holes for mounting bolts. The explorer rear end has 2 lengths of cables, I ordered 2 of the longer ones (Dorman P/N C660004). The problem with those is that the cable ends don't match the newer mustang equalizer bar, so I cut off the cable ends and welded new ones on. Brackets are welded on the tunnel, and the brake seems to work pretty well, I'm sure I can adjust it but I want to test it out and let the pads break in etc... I will get some photos soon, I already have some up on my instagram. Interestingly the late model parking brake handle fits really nicely around the classic seat giving a very ergonomic pull. It looks like the handle was made for this car, but its going to need a pleather boot to cover the mechanism.
21 - 29 of 29 Posts
