I have just installed a new centerforce 1 clutch in my 1965 Mustang and the pedal pressure is greater than the stock clutch I replaced All adjustments are correct to spec.
Any sugesstions. Can the z-bar alignment cause this condition?
I installed a centerforce clutch disc and pressure plate. I presume you are talking about the pressure plate, as changing the clutch disc alone will not change your pedal effort. I went with a cable clutch instead of the factory linkage so I cannot help you on that part of your question. Good luck.
sure it's fun (most of the time), but it's only a car.
I had the Centerforce 1 also, pedal pressure was slightly higher then stock, not alot. Make sure your not binding somewhere.
BillGear
302 Roller, 5 speed, FTI Custom cam, AFR heads, 17 TT2's, Holley 650dp,see it at http://www.289mustang.com
http://www.289mustang.com/images/vmfcar.jpg
