Well now its squeking like mad. its happening at all speeds exept at a complete stop. whats this sound like to you guys?
It should be easy to find now that it does it constantly. Sounds like a wheel bearing or brakes. I'd jack it up and spin the wheels to see where it's coming from.
Good luck
If it is making the noise at all speeds have some one else drive the car at a slow speed and you walk beside it. This will allow you to at least figure out where it is coming from. Then jack it up and take a look.
The tough part of this is having some one else drive your car while you walk beside.
Good luck in locating the noise and let us know what you find out.
I had this on a little S-10 pickup, it was a u-joint...had worn a hole in the side of the cap. Guess I caught it just in time. I never did like those cheby joints because I can't grease them, at least until they are changed out...good luck.
