I have asked this before and thought i was going to change the whole thing, but the more i think about it i dont know. :: I want your opinions on what you would do if it was your show car.
The pass side 1/4 panel has 3 inch hole in front of the rear wheel. The back has had two seperet lower patches put on. Also the lip around the wheel well is dented in a few spots. I have a new full 1/4 for that side. I know some have mentioned that the lines on a new one may not be as sharp and also that the side scopes may not fit right, but i tested the side scopes and they seem close. (i have pictures in my gallery) So i was going to go a head and try to change the whole thing, but i dont know now it seems like a huge task. I melted the lead out of the roof seem and it looks like it is impossible to seprate the two peices. Then what do you do where the 1/4 meets the rocker? Besides i am conserned that the metal is thinner and the lines might not be as sharp as the original. ( i can't tell this but you guys have done more then i and would know) The problem i have with only doing part is first what to do with the weld seem in the trunk? Second how do i know were it belongs? The trunk drop off was replaced, and i dont know how far it is really suposed to extend down. I cant use the other side as a reference as that side has been replaced two. :wall:
I know someone here that shows their cars must have had to replace these so what did you do? :: I want it too look good when it is done and i want to be able to do it my self.
