I'm planning to swap the single reservoir brake cylinder for a dual-reservoir. Does anyone have instructions on doing this? Is it complicated, or should I hand the parts and the job to my mechanic?
Deke
You should be able to do it, it is fairly simple. I was able to and have virtually no mechanical background. Do you have power brakes also? If not, you should look into putting in a booster while you have the brake system apart.
Thanks, I'll look this info over. The car doesn't have power brakes, but I've never had a hard time braking the car. I would imagine the power boost would make them very sensitive...just tap and you're braking.
Deke
