I have issues with my carb. It is an old vacuum secondary that I can't get adjusted to work correctly.
I bought a 650 mechanical double pumper and decided to change the currect Offenhauser 360 intake to an Edelbrock Performer ( 351W ).
Since I have never done this before on a windsor, do I need any gaskets for the intake to block or to the heads? If so does anyone know the part numbers?
I don't want to drive to the performance shop on Sunday ( which will be closed ) when I find out I need something...
Thanx in advance!
you will need a intake gasket set
i usualy don't use the front and rear seal to the block just lay down a good bead of rtv black
might be a good time to swap out the thermostat too
chris
