41 - 60 of 182 Posts
Discussion Starter #41
How do you insert the pictures into the post large like that? mine will not allow me to do that or to even attach them not. keeps saying its to large?
I import my photos into photobucket (organized into a specific library for various projects).
I then navigate to the picture i want to post (in photobucket).
On the right hand side of the screen (in photobucket) you'll see 4 fields
* Email & IM
* Direct
* HTML
* IMG
Click on the 'IMG' text box and, in my case, it'll automatically copy the link. You then paste that into the post your writing up. Remove everything in the pasted section EXCEPT for whats encapsulated in the
tags. Ergo, remove the http://blablah in the first half and the [\URL] at the very end. If you leave it in it wont effect the image population but it'll leave that block of text in your post and it wont look quite as cool. Hopefully that explains it?
Discussion Starter #42
I'm dealing with the same problem with my rear valence.
Please post up some step by step pics as you fix yours...need all the help I can get.
Sent from AutoGuide.com Free App
Absolutely!! Hopefully i'll get a chance to start on it this evening. Afterward, if you have any questions, feel free to send me a PM.
The convertible riser creates a rigid structure between the two inner rocker pieces. It's a single, solid piece. I'm not sure how much flexing those inner rockers do since they are heavy tubular steel, but if they were to flex at all, the convertible rocker would eliminate it.
Whereas the coupe seat risers are 2 individual pieces that wouldnt create as much (if at all) additional rigidity. Make sense?
The shorter answer is...probably nothing / not much but add piece of mind :grin2:
I mainly used one for the rigidity but it also lowers the seat about an inch. More headroom and easier to fit taller seats in there.
Discussion Starter #44 (Edited)
"Finished" the metal work portion of fitting the rear valance this evening. I put that in quotes because I'm on the fence about welding the whole thing to the car versus keeping the gaps. I'm inclined to weld it to the car since I'm planning on blending the fender extensions to remove those gaps as well. Decision for a later day.
Onward!
First thing I did was separate the ends from the valance. I used a body say (fancy name for a air reciprocating saw) to keep as much of the valance as possible. I did this so I could keep the edge without having to get fancy with it. I then tacked the edge to the car. That way i could sure up the gaps the way i want...and I only have 2 hands...
Then it was just a matter of cutting metal to fill the gap. I did a small section at the bottom first since i was having trouble keeping the valance where I wanted it to appropriately fill the gap. I used a 90* grinder w/ 36 grit rolocs to shape the edges to fit.
Weld up the rest of the gap. If you're a mediocre welder like me, you'll have a lot to grind off...
I also relocated the mounting brackets on the inside. Drill out spot welds, mount to car, weld tabs to valance.
The other side wasnt nearly as bad but followed a similar plan. I didnt have to cut pieces to fill. The gap was close enough that I could just fill with wire.
I also ran a light under the welded gaps to make sure it was all welded. After I epoxy prime it I'll smooth it out with some fiberglass filler. I'm going to do some more smoothing work but I ran out of rolocs...
In other news...sounds like I'll be picking the block up this week. Which spawned a pre-emptive call to Summit. Santa in the brown sleigh dropped off round 1 of the order. I'll be putting in another order this week for ignition system, wiring, brakes, and to finish off the cooling system
Discussion Starter #46
Excellent! Glad I could help.
This whole endeavor took me about 4 hours to finish. I figure another couple hours to get it perfect with the filler.
If i get time this week I plan to:
- clean the engine bay (it's dusty)
- clean up some previous owner welded garbage that made no sense
- seal a few extraneous holes
- go over the car one last time for any other exterior metal changes
- strip the dash and pillars
- start DA 80 grit sanding in preparation for Epoxy
If I happen to get a call from the engine guy I'll take a break from all that nonsense to build an engine!
Discussion Starter #47
Well no call from the engine dude so it was a body work weekend. Got the back half of the car and the roof DA sanded. Sealed up the emblem mount holes (the 3 finger emblem thing). I also cleaned and finished up some welds.
I had my heater going in the garage as an experiment to see if i could keep the temperature up. Metal temp and air temp both stayed well above 70 so I decided...what the hell...lets spray some epoxy (plus it was starting to flash rust).
I use the DevilBiss 'DeKups' system so I got it all setup. Mixed a container of epoxy...1:1 according to the instructions. Let it 'induce' 30 minutes. During that time I got my air feed setup and checked my tips. 1.3 and 1.8 were still in the drawer so I knew 1.5 was on the gun. Put the hopper on and got ready to spray...
This is where things started to go off the rails...
After a crap ton of fiddling with the fan, flow, air pressure, EVERYTHING...i just couldnt get the gun to spray like it should. I set the flow low and the fan tight just to get something consistent. Even then...it would splatter every so often and letting the trigger out it would dribble. I continued to spray since...it's just primer and will get sanded down anyway.
As i started taking the gun apart to clean it I noticed the air nozzle wasnt seated all the way. Then it dawned on me...i let a friend use this gun a few months ago. It looks like he put it back together with the flow seated all the way down which prevented the air nozzle from seating. I got it put together the way it should be...i really hate seeing splatters!!
Hopefully that solves it and the gun will go back to spraying like it should.
Discussion Starter #48
Engine build is hung up waiting on the AFR 205's. Since I had to go with the upgraded springs it's taking them a little longer to ship. No big deal since there's still PLENTY to do on the car.
This weekend was all about epoxy!! Scuffed up the e-coated new parts...well...most of them. Also ran the DA with 80 grit over all the other metal. Mixed up the SPI epoxy. While it was inducing I cleaned all the soon to be coated panels with Eastwood prep cleaner and got to it!!
Sprayed 2-3 wet coats and ran the heater overnight to cure it. Sadly...I couldnt get the whole thing done due to space limitations. I still have the edges of the doors, headlight doors, headlight inserts, underside of the hood and some other piddly things. I'll look to doing that stuff next weekend provided I dont have an engine to contend with. I dont like having so many irons in the fire at one time but such is life.
Here's a photo of the epoxied stuff. I had already closed the doors to start getting the temp back up so the pic kinda sucks...
Couple other things...my painter has bailed on me so I'll have to sort that out eventually. I think I'm going to finish the body work and then go about 'building' the car (more or less). Should take me until the end of the summer and then figure out what to do.
I've also been going back and forth on what transmission to run. I was initially thinking a T56...that later changed to a TKO600 so I wouldnt have to modify the tunnel. Now I'm back to the T56 since I've done so much metal work I figure...whats a little more.
Anyway...decisions to be made later i suppose
Discussion Starter #49
I think I have the painter stuff sorted out. I have another guy I used long ago on some other builds in my hometown that I'll hit up when the time comes. That's still a long way off. Since I'd have to cart it 200 miles and it has a fiberglass front end, I'd rather not use the winch to pull it up on the trailer. That means we're full steam ahead on getting this thing running and driving!! It also gives me 6 months or so to decide on a color.
Now for progress...I picked up the long block on Friday.
Saturday I touched up the paint in the engine bay. I had sat the hood on the roof several months back and it slid off and marred up the bay like 3 days after I sprayed it. So I scuffed it and sprayed a light coat to blend and seal all the messed up areas.
I then spend some time installing the intake manifold studs and oil pan studs in preparation for building.
Sunday I set to work finishing the engine. Everything went together mostly without a hitch. I did have to run to the hardware store to pick up some stainless bolts for the timing cover and water pump.
Lower end with the pickup. I used a Canton pickup tube:
Finished product!
The day was pretty young so I decided...what the hell...lets drop it in! I'm using Ron Morris mounts which made it crazy easy to put in...like border line cheating. I think the whole install took like 15 minutes.
Side profile:
I did notice that I got the wrong water pump for my application. I need one with the outlet on the drivers side to avoid having some really stupid water hose routing. So the pump will be coming off in the near future and swapped out. Which means if anyone's looking for an Edelbrock Victor High Flow pump (8841) I'll be looking to sell one in the near future.
I think the next steps are going to be:
- front brake line routing and plumbing
- finish installing the serpentine system and alternator (i'll have to call March and either swap crank pulleys or see if they have spacers to get everything to line up proper)
- EPAS installation
Then its back to body panel alignment so I can let my funds build back up.
Discussion Starter #50
Well I got a Flow Kooler, drivers side inlet pump only to discover that it doesnt fit the timing cover...which i kind of expected. So the cover has also been added to the sale bin. I also ordered the wrong bloody alternator. I apparently got one designed for a truck and the mount points were all sorts of wrong. So that one is on it's way back to Summit and the right one should be here tomorrow. I've ordered a 1 wire, 150amp unit.
Why so much amperage? I figured i'd probably need the help since this thing is going to have 2 12" electric fans, MSD 6al system, Sniper EFI w/ electric fuel pump, electric steering, and probably around 1000 watts of sound...or more.
Pulled the engine back out on Sunday to make it easier to swap the pump, cover, etc. I also figured this would be a good time to bend, flare, and install brake lines. I bought a coil of 3/16 stainless brake tubing and got everything bent and flared. I didnt heat the ends before flaring but it doesnt look like they cracked or anything like that. I was doing a bubble flare and the lines are seated good and tight.
In the process of fitting the brake master cylinder and proportioning valve from Wilwood, I realized that I couldn't use the bracket that Wilwood supplies to mount their proportioning valve on the master cylinder since I plan on using a hydraulic clutch. The bracket would have covered the clutch master whole. So I've relocated it to the drivers apron. I mounted it a little lower than the lines would have liked so I'm going to make up a couple spacers to get it off the wall a little. That way the lines wont be jammed up against the lower part of the apron.
Which hydraulic clutch setup are you using? I have the Wilwood master with a modern driveline hydraulic clutch and was able to use the bracket wilwood sent with the master.
Modern Driveline doesn't use the original clutch rod hole on the 65/66 setup.
Discussion Starter #53
Lots going on over the last 3 weeks but it's the slow, tedious kind of lots.
I called my painter because I know some painters wont take a project in that's already had work done to it. Do to family and work constraints (he paints stuff on the side), he's not going to be able to take my car UNLESS the body work was all done. Which is actually fine by me since I kind of wanted to do the work. I've never done it before and want to learn.
I also checked in with another guy I had used on my GTO like...15 years ago. That conversation was not so good since he did the whole "throw a scare away price out there" to make me go away. Dude quoted me 27k so...not using him.
Thus...I've been finishing some metal work, putting down filler in areas, re-epoxying when i cut through, and trying to set gaps. Both the doors and front fenders are repro parts. As such, they are not fitting that great. They fit okay...but not great. I got the doors about as good as I think I'm going to get. The tops line up with the contour of the quarter. The bottoms have a consistent gap. However, the styling doesnt "exactly" jive. I have the upper part of the styling matched but the bottom part (on both) not so much. It looks like the styling on the doors are off about 1/8" or less. I'll probably post a thread about that in the General channel for some quick consultation.
To add insult to injury, the gap on the drivers door to quarter panel is...weird. I'll post a pic of that later today. It's...wavy...fixable...but wavy. I have conceded that I'm going to have to put in some rod on the gap edges to tighten them up. Not a big deal.
Now...confession time. Awhile back I tin canned the drivers side of the cowl. The top hat had some rusted out areas and, instead of doing it the "right way", I slapped some fiberglass on the bad stuff and moved about my business. I knew it was the wrong way to do that and it hasnt been sitting well with me.
Since it sounds like I really have no timeline on getting this thing to a painter and the thought of a half asses repair was giving me agita, I set out to do it the right way yesterday.
This really wasnt as bad as what everyone seems to make it out to be. I think it took around 2 hours to have the top cowl pulled off. It has some rusted out areas that will need to be fixed but I think it's easily reusable. I'm glad I did the extra effort to get to the lower cowl. The rust was a little worse than I had expected and now, I can appropriately patch it.
Since the rust is fairly well isolated to the hat sections and a couple smaller areas at the lips, I've elected to not replace it as an entire section and patch. That way I can easily line up holes from the spot welds and make sure it goes back the way it should. I'll have the order into NPD today or early tomorrow and, with any luck, have it buttoned up next weekend.
If you look at the drivers hat you can see where I slathered dynaglass...i'm not proud...
Discussion Starter #54
Well I had to set aside the perfectionist in me yesterday. After several days of moving and dorking around with the doors, I think they are about as good as I'm going to be able to get them. I had to open the hinge adjustment on the passenger door a little with a carbide bit and then play around with the inboard / outboard adjustment.
The upper part of the door's contour is off about 1/8 of an inch. Could be due to the reproduction door, the fact the quarters were skinned previously, or a combination of the two. I have the quarter to door gaps, what I consider, perfect. The rocker to door is a little wide but I can tighten that up with some filler rod. I dont really like how the front of the door angles out away from the rocker a little but it's probably going to have to do.
To 'fix' the weirdness with the door, I've set the outboard adjustment to match the contour of the upper part of the quarter and am going to have to fill in on the quarter. I cant really see any other way to do this.
The drivers side, other than the wavy-ness on the door gap, fit rather well. I'll still need to shape it a little to match the contour of the quarter and tighten the gaps up...a lot on the rocker side.
Since I'm waiting on the cowl patches from NPD, i'll start doing some of this weird, annoying shaping work.
Lines match up...the picture makes it look optically weird but they line up:
Here's from the rear where I'm thinking i'll have to build up on the quarter:
Discussion Starter #55
Whoa...I'm behind on posting!
After consulting with more knowledgable folks (thanks Pete) about the quarter problem, I learned building up the quarters is not the right way to fix them. The quarters were a reskin by a previous owner and, when they installed them, they seemed to have set them in a little to far at the pillar. So I broke the welds free so I could adjust it. I was having a tough time getting leverage from the back side so I broke out the stud welder. I set some studs and pulled the quarter to where the contours matched. Once I was happy with the contours I welded it down. I still need to epoxy it and then filler the seam.
I also aligned both doors...most annoying exercise EVER!!
Then it was time to address the lower cowl. The passenger side was pretty easy as it wasnt super chewed up. I cut and spliced a section out of the hat and a small area in front of the hat. The drivers side was not as easy since I tried to repair it via the tin can method...it was a pretty sad attempt. Turns out...I'm the previous owner on this one.
I ended up cutting out the whole thing and putting a new top hat patch panel...which I screwed up the cut on. So I ended up having to use strips of metal cut to fit the gaps. It was a pretty miserable experience that all could have been avoided if I'd taken my time a little better. Oh well...it's done now. I verified the welds do not leak but for safe measure i added fiberglass reinforced filler for an added seal.
I'm going to be sealing the vents on the upper cowl as well which should help preserve the lower cowl.
Now, for those out there that are going to freak out about that last statement...fear not! I'll be using an aftermarket climate control system like classic auto air or the like. I'm also debating cutting intake holes in the upper cowl under the fenders.
I have the upper cowl mostly welded back down. I have some smoothing and touchups as well as a few things that I need to fix from the previous hackjob.
Classic Auto Air has you put some metal plates to seal off the intakes, so you might as well do that now since you have everything apart anyway.
Not that you need the cowl off to do that, but you do put screws through the bottom side of the cowl. Then you can put some sealer around the screws from the top side to be 100% sure they won't ever leak.
Discussion Starter #57
So fixing the cowl took way longer than I had expected...but it's done. I finished a few small welds on the cowl today.
During the week, I worked on sealing up the cowl vents. I did have to take a few days off to have a piece of metal removed from my eye. The damn thing went right around my glasses...anywho.
I created a template out of cardboard and then drew 6 plates on a piece of sheet steel. I then cut them out with the plasma cutter...intentionally leaving them big so I could grind them down to the appropriate size cause I dont trust myself to get it right on the first try :-D
Then welded them down. I spaced my welding sessions out to keep the heat down on the metal to prevent warping:
What you dont see there is that I ground the welds down so each piece is damn near flush on the cowl. Some epoxy followed by filler and that project will be done.
Then I set out to start fitting the hood, fenders, and remainder front end pieces. I knew I was going to be in for a bit of a fight due to the reprop fenders. I lucked out pretty good on the passenger side as it was pretty close. I did have to massage the mating surfaces near the cowl to get it to line up. It was initially about 1/8" above the cowl line. I tweaked the underside lip to allow me to force it down a little. It fits REALY good now. I did have to warble out some holes but that's no big deal.
The fiberglass hood also fits surprisingly well although I feel like it has a slight warp in it towards the edges. When you have the hood lined up at the cowl, the center area creeps up above the line of the cowl. I'm not too terribly worried about it just yet and I have some time to figure out how I want to address that.
The drivers fender fits like poo...It initially had a bow right in the fenter of it when lined up to the hood. I was able to work that out and now it's pretty darn straight at that line. The gaps by the door are atrocious. Luckily I have plenty of 1/8" rod to close the gaps up. On the plus side...since these fenders are pretty thin sheet metal...it's pretty easy to get them worked into the appropriate shapes.
For example, I was easily able to shape the front contours of the fenders to meet up with the fiberglass apron. I expect minimal filler to make it perfect.
The passenger fender did require a little bit of gap filling...
Not quite done. I need to do some finish welding on this to seal it up.
Once I'm happy with gaps and any other metal work, I'm going to; take the fenders and stuff off again, re-epoxy in black...everything, re-assemble setting gaps, and begin blocking!
Also...here's the drivers side fender...ewe
Discussion Starter #58
Well...I think about 6 hours or so later and I have all but one gap sorted out. I have become one with the 1/8" steel rod...
This is the new drivers side gap. This pic was actually taken Wednesday before I'd finished the bottom. I completed that yesterday
I also closed the gap on the bottom of the drivers door. I'm not quite done with that though. I still need to weld the inside portion of the door. The rear part of the drivers door also needs to be touched up still.
The passenger door just needed some added to the bottom. This side is just about done. I have to smooth out the inside welds and then I can re-epoxy the door.
I noticed after taking this picture that I had a couple errant weld blobs (before I got a TON of practice welding ;-) ) that I smoothed down. Overall...I'm real happy with it!
I did some light filler work on the roof and hood. Now that major corrections to the fenders, roof, and hood are done I figured it was time to start getting it under black epoxy. So that's how I ended the night. Both fenders, hood, and roof got their first round of epoxy. Second will be tomorrow.
With any luck, I should have the whole thing in its final stage of epoxy, spray build primer, and start blocking by the end of next weekend!!
Discussion Starter #60
@Mustrick
I just got my headers last week. I had Accufab build a set. I havent tried to fit the engine with the headers just yet but they look like they should fit...
I'm currently in full body work mode. I sprayed the black epoxy yesterday. I have a couple areas that I need to skim some filler and a few gaps to finish. Then I'll be on to blocking!
