This thread is for anyone that may be considering upgrading the headlamps in the classic to something better than the lacking sealed beams. I meant to put this up a little while ago. I've been interested in doing this for a while now and after much research decided to go with Cibie H4 E Code assemblies.
These are Valeo part number 082440 The runner up is most likely the Hella E Code lamp. I also like that the Cibie has a convex lens that looks more like an original bulb, whereas the Hella lenses are flat. I did also notice that Hella makes a DOT lamp, but I like the nice beam pattern that the E Code produces and well as the fact that it emits less glare to oncoming traffic.
These pictures should give a decent idea of what the difference is. They did need to be aimed down just a bit in both pictures, but the aiming is the same for both. I did that after the switch. The camera was on a short tripod on the roof for the pictures. The GE Nighthawk are halogen sealed beams.
Having a relay setup along with the improved optics of quality assemblies and a pair of good non-blue bulbs from Phillips or GE etc are just about perfect.
