The cigar lighter and emergency flashers are not working on my 67. Everything else on the instrument panel is fine. I thought I'd replace the flasher and while doing so I thought I'd better check to see if I was getting power to it. When I checked (with a test light) I couldn't find any hot wire. It is my understanding that the lighter should always be hot but there's no juice coming through the blue/white stripe wire (40). Checked the fuse and it's okay. Disconnected the harness and found the only hot wire from the fuse box is the yellow wire (460) to the instrument panel. The white/red stripe wire (385) from the fuse box eventually connects to the flasher and wire 40 so I assumed it would be hot also, but it is dead.
Am I wrong in my assumption that 385 should always be hot? Or am I way off base? Is there another way I should be testing? Just trying to make sure the wiring is good before replacing the flasher and lighter. Thanks.
