cleaning valves?
679 Views 3 Replies 4 Participants Last post by  camachinist
Is it alright to blast the carbon off of valves using a 100 grit aluminum oxide? or should i wire brush them? or should i.....
i've always had my head work done down at the local shop where they put them in that toxic looking bath. can't imagine they would charge much to dip them.
motor
Blasting them is the quickest way. Just be sure not to blast the stems. Scott
Every day is a holiday if you love your job.
Current projects: 65 Fastback, 68 Coupe Oval Track Racer, 64 Galaxie 500 XL, 54 F-100 Pickup
Blast away....just don't get the stems with the stuff...
Remember, you'll need to grind the faces before re-installling in the head...
Pat
http://albums.photopoint.com/j/View?u=1570936&a=11937754&p=42910787.jpg
