so up until yesterday I thought my car was running just fine, until she ran out of gas (my fault) and I guess a bunch if crud from the fuel tank, both small and large, worked it way unto my lines. I found out because she didn't want to start after I gave her half a tank. So I disconnected the line to the carburetor and placed a bucket to see if the carb. was even getting gas. Nit as much as it should get, and it had crud. So I'm not sure what to do.
I know I have to replace the fuel pump, not that big if a deal, fuel filters as well, ill probably add an online fuel filter because of fear. Do I replace my tank? Can I clean my tank? Can I clean my line? With a line cleaner or gum out? I know That I will open the carb and spray all the holes just to be safe. Ideas? Suggestions? Tips n' tricks? Much appreciated in advance!!
-TJ
-TJ
