How much shorter was the new rod than the old one?? Probably hard to say since it ended up on the road somewhere...*G*
All I can say is that the pressure plate fingers are never more shallow than when everything is new....as everything wears, they push back more and more on the throwout bearing and fork....
Question: what do you use now to set your throwout bearing freeplay (aka clutch pedal freeplay) since the threaded rod is gone?...is the pivot stud on the bellhousing somehow adjustable?
Did you check your new throwout bearing against the old one for consistency?
Tell me what happens if you put the car in first, depress the clutch, and try to crank the engine....
I'm stalling for time until the manual trans gurus get here...*G*
Pat
http://albums.photopoint.com/j/View?u=1570936&a=11937754&p=42910787.jpg
Pat
