Ok you guy's, with all the slack I got in regards to trading the vert for a bronco. You all talked me into keeping the vert.
So here I am working on it and here is my question of the day.
I pulled out the clutch and brake pedal along with the support. Going to install new bushings and clean it up. Now on the clutch pedal where the main pin connects to the pedal is loose, it looks like Ford had some way of jimmying it on somehow, and I would like to know if it is supposed to have some movement or should I through a tack weld or two so that there is no movement and it remains solid. I am talking about where the cross pin that goes through the support actually connects to the clutch pedal if that helps.
Thanks again.
Bob T
Thanks again.
Bob T
