So I dropped in an 88 302/T5 and get welded the brake cable plate to my new clutch pedal so the cable works. Installed an adjuster at the firewall and adjusted it so the clutch engages about half way down. The only problem is when I push the clutch to the floor, the pedal stays on the floor until I give it some help. I think the travel is going to far and the spring is actually trying to pull it back around. Anyone come across this before and how to fix it? The return spring is new.
