1 - 2 of 2 Posts
How do you get the return spring back on the pedal upper pedal bracket up inside the car above the dash? the one that mounts on the clutch pedal to the front of the bracket?
any help would be appreciated. thanks Bob
Put pennies between the coils to extend the spring. Once installed, you can remove the pennies.
Another trick is to install the forward end, then use a good piece of leather strapping on the other, and pull like crazy, and install the back end. When done, cut the leather and remove.
1 - 2 of 2 Posts
