1 - 9 of 9 Posts
I have not seen this intake yet. An older friend of mines brother stopped by yesturday with a guy who claims he has a 289 weber intake only for sale, no carbs. He also claims to have to older vets. What is it worth? thanks bob
Several different styles; Carbs facing each other, facing the same direction, intakes for 48's, 46's, newer ones use a thermostat and housing like a standard intake.
Value would depend on which one you have, but for a vintage 48IDA COBRA intake, prolly $450-600 range.
Thanks, I think he is hinting for a higher value than that. I will see if he will bring it over so I can take a look at it and maybe post it for sale here.
I would consider that to be a fairly exotic setup. Tri-power repops are like $1200.
Not to dispute Art, I've seen Webber units on ehay go for $2k+ depending on model and condition. And that's not to say ehay is a realistic price gauge. But your guy may be thinking that high.
IMHO if you could get it for 4-600, I'd jump on it.
Discussion Starter · #5 ·
It doesn't have carbs. I also don't know if it is a tri set up or something else. He was supposed to stop by last night so I could take a look at it. He did mention that the COBRA was opened lettered.
I'm a little slow in piping in, but the intake will be a minor expense in a Weber set-up. Intakes can be found for as little as $200. Some folks, like Art said, will ask more-- double plus.
Carbs are VERY expensive, running from $400 to near a grand EACH (as I've observed on eHay). In 3 years of watching eHay Webers (not constantly, mid you) There's been only one set of "Shelby American" Weber carbs come up. IIRC the set was a no-sale at $4500+. The Shelby American carbs did have a special P/N on them and were serial numbered. Now, I guess you could go with IDFs; they're priced about like a good used Holley, each.
Hollow lettering on the intake isn't as indicative of an original part as it is on valve covers; reproductions can scarcely be told from originals.
In addition to the carbs and intake you'll need linkage, a waterneck, a thermostat (goes inside the radiator hose and is actually a Ford tractor item), you'll have to modify the waterneck if you want a heater, air filters of some type if you're going to drive them on a regular basis, a fuel pressure regulator and gauge (Webers aren't forgiving when given excessive fuel pressure, i.e. above 5 lbs).
If he's wanting a couple of hundred, I'd buy it if not for any thing else than to hang on a wall, but at twice that I'd wait until a complete set-up comes available at the $2-3k dollar range. Just my opinion.
Discussion Starter · #7 ·
Thanks for the info. I think he is one of those guys who likes to talk about what he has and not sell anything. Since he is a friend of a friend I thought I would be nice and find out what a fair value was for the intake. I told him I didn't know much about them and that I wouldn't give him a $100 for it. Well see whay happens.
I was just using the tri-power as an example of the prices on something vintage and unusual.
Looks like you've got some solid info in this thread to make your decision on.
Good luck.
hi tom;
i'm late in piping in too. if you're referring to my old setup, i did eventually sell it for $5k+. it ended up on a shelby re-issue car. unless you find a complete setup ready to go for a steal, plan to spend in the $4k+ area to get what you want with a few extra calibrated parts to boot.
btw, your linkage pics were/are very helpful......
mike
1 - 9 of 9 Posts
