·I finally unwrapped the underdash harness and found the "pink" wire. It is connected to the firewall plug as it should be. Both the 65 and 66 diagrams show this connects to the starter switch. My question is how!! The pink wire continues back to the fuse box area. I haven't unwrapped it that far, but it does continue beyound the switch area and accross the back of the gauges. I have the ignition wire that is supose to connect to the pink wire and it was wired direct to the coil via resistor block. I am trying to get it back the way it is suppose to be. thanks for the help.
