how is the steering column sealed in the firewall?
how is the inner rubber grommet held in place?
what is the sealant used on the engine side?
thanks
iowa
The 66 has a flat rubber seal screwed to the firewall, and the column pokes through it. The bottom end is sealed with a large rubber grommet.
Glazier/Nolan G04014:
Glazier/Nolan G04013:
isn't some kind of seam sealer
used on the column and on the
bottom large rubber grommet
on the firewall on the engine side?
iowa
I don't think there is supposed to be any sealant on the grommets.
what keeps them from working loose
and coming out
with potential fumes coming in?
iowa
All firewall penetrations were sealed with sound deadener at the factory. If you're wanting to do it as original, sound deadener will coat the entire flat grommet on the firewall side and extend 1 - 3 inches down the steering column.
Evercoat sound deadener in a spray can has a very similar appearance to the original sound deadener. NPD carries it.
