Well after replacing all hardware, all 4 shoes, front wheel cylinders, All soft lines, All 4 drums turned, Bleeding, replacing porp valve, check all lines for kinks, Adjusting. My car still pulls to the right when braking. However it seems to be better than before. Also seems to pull harder as the drums get hot.. I.E. longer I drive the car. I am about to go crazy... Is this just normal behavior for old drum brakes or Is there something I should still check. When braking hard I have to fight the steering wheel to turn the opposite direction to keep her straight.. I can not wait till I have enough $$ for front disk brake conversion.. Can the emergency brake be causing any problems? That is about the only thing I have not checked into. Thanks for any help.. I am game to try any suggestions..
