The joint in the middle of the drivers window drops down a little. When the window is all the way up it hits that joint when the door is closed. Is there an adjustment on the rear of the top mechanism or cable system?
Frank
There is an allen head bolt just above the rear quarter window handle that has a locking nut around it.
The bolt when turned, moves an eccentric that can raise/lower the alignment.
Put the allen head in the bolt head, loosen the outer nut and turn until you get the alignment you need, then lock it back down with the nut.
Thanks for the help, as soon as it gets above freezing I will try to adfjust it.
Hope that works for you. It did for me marginally, but not all the way. I'm working on the attachment points at the back and hope to gain something there....
